Help Please help..new Ace
Hi i bought a Ace two days back from Inida..i m an Indian..P..and upgraded it to 2.3.3 (S5830xxkp8) using odin software..
Can i upgrade it to 2.3.4 using kies directly?...coz i think XXKP8 is a russian firmware..
or I ll have to intsall an Indian firmware first? and den use Kies upgrade 2.3.4
Also when i try to install some games..it shows device memory full...but in SD card and memory it shows almost 127MB free...
Please help..
I m new to android
There is an official 2.3.4 in your region. Why flash unnofficial buggy roms? (and voiding your warranty)?
yea..i dint noe it..learning it...
so can i now reverse it..by putting 2.2.1 Indian stock version and then using kies update??
i really dont think so.... read the forum though as there are a few threads on downgrading. You could always flash a rom from samfirmware but not sure if you will be able to get official after that...
ok i downloaded the froyo asian version...but my Odin shows 'Invalid Binary error' after putting bot, phone etc...any comment on that?
