I found the apps the i was looking for on the appbrain market, but after i click it, it show a msg as "the requested item could not be found", i cannot download and read the review of it... Thx in advance for your help
You need to tell us where you are, as the Market is not available in all countries.
There are several sites that you will be able to use if the market is not enabled in your country, but before recommending sites we need to know the problem.
I've faced this problem too, just go to Market app & search for the same app. If you don't find it, chances are that its not supported in your market. This is an issue with AppBrain, as they don't filter app results based on market availability.
