Help Please Help Screen Flickering
sgs
Hi, I have a strange problem with Galaxy S, can somebody please check if they do experience the same thing.
My battery is low (about 13%), I'm connecting SGS through WiFi to the Interent. Any time the device is downloading something: web page, image from Picasa, etc. on the screen appears flickering tiny lines, like magnitic distortion. Once page fully loaded screen become nice and clear.
If I plug power, USB, the screen and download happens normally.
I tried different setting (brightness of screen, vibration on/off, stay away from electronic devices) - nothing helps. As long the battery low, lines are coming back and flickers.
Please help. :eek:
I have the same symptoms as yours, but my galaxy's screen flickers when only edge signal connection is on, not wifi. However, there's no impact from the capacity of the battery even full or low. It may be the h/w problem of the unit and I'll bring it to SS service soon.
hi
this are the indications that the screen is going to fail in short duration. i had a brand new set on 6th august by 4pm and the screen was glowing like auto contrast then the whole display was flickering and then the total display failed in three hrs and went to samsung service centre and they told screen has failed and gave me dead on arrival certficate for new replacement
regards
naren
hi
regards
naren
Thanks for your information. However, I just found out later that the leather case that I ordered from Korea is composed of metal. When changed to silicone, all flickering screen completely disappeared.
