PLEASE HELP! SOFT BRICKED PHONE
So I rooted my SM-G503T1 (Samsung Galaxy Grand Prime from Metro PCS) and it worked perfectly. A month later I decided for some mysterious reason to turn off OEM unlocking. I wanted to reboot my phone some time later so i did. Booting up it said Custom Binary blocked by FRP Lock. I googled the issue and found that people got this fixed by flashing the stock rom. so i tried this. Whin the download finaly finished I booted my phone to download mode, plugged it into my computer, and flashed the md5 using odin. But it failed. My phone saying that FRP Lock was blocking it. Also in the process it soft bricked my phone. on the screen it says. "An error occured while updating the device software. Use the emergency recovery function in the smart switch PC software. So I did but idk my serial number. I dont have the original device box. So thats also scratched off. So to summarize. I have a soft bricked phone with frp lock on and i dont have the serial number. PLZZZ HELP MEEEE
ik where to go from here. my phone is now a tmobile phone but by flashing the metro stock firmware with oem unlocking on i can get it to be a metro phone again
ok so ig i was wrong. now im stuck with a tmobile phone and a metro pcs sim card. its not that big an issue but its kinda trippy that everything says tmobile but the service it metro pcs. also i cant access my account via the metro app. any ideas on how to fix this?
I don't have your phone and got the links from helping others with same problem. Your best bet would be to create a account at XDA and ask in the threads I linked. A lot of folks working on the problem there.
Good luck.
Good luck.
ok well you helped a lot thanks. Without you my phone wouldnt be functional for shit. A million times thank you.
