please help with my cappy
cappyguy
Ok I need some help! Last night i wanted to try to run a new rom so i found some instructions on youtube. It all started with using oden one click, i started to flash my cappy back to stock and oden got hald way done then said failed. Ok so my phone being in download mode and stuck half way i pulled my phone and it was then soft bricked so i found the one click unbrick and all that did was get into a boot loop. So out of oprions i used oden one click again and i got my phone back ir so i thought i can call and text but nine of my appa work not even app store every time i try to open an app it forxe closes. Anyone have any ideas.
Update: I just lost my mind and did a factory reset. Now things seem to be back to where the phone was when it was new so now I am trying to upgrade to an ice cream rom. wish me luck.
Hi cappyguy:)
What kind of Samsung device do you have:confused:
I will check and see if I can find something to get you squared away.
I have the Samsung Captivate... Yeah it's an older phone but it is my first android and after having it I will never use anything else.
Ahh just saw your update-glad everything is working for you again:D
If you need help with anything else just say the word cappyguy:thumbup:
