Root please help with prevail..sd card error....stuck in recovery!!
CHEONY81
please help..I partition my sd card with recovery.i download 2 roms to test out.when i went into recovery to flash rom,but said error cant mount sd card..so i reformatted my sd card to original size and fat 32..but when i insert back into phone to try toflash still gives me same error..can someone please help..i am stuck in recovery and cant flash anything..i tried to unmount sd card and still get error..i tried ti plug phone into computer by usb cable and mount usb,and when i try to open drive i get cant open drive 7 error,also asks me to reformat again..
Have you tried the SD card in another device or used an adapter for the card to plug it into a computer? I just want to rule out the possibility of a faulty card.
On a side note, I'm moving this to the ATR subforum :)
i was able to get phone back on through odin..reformatted sd card..i plugged in sd card to my computer through card reader and it picks it up and reads it.but when i insert it into phone and doesnt pick it up sd card..
i got it to work..i fixed it by reformating using EASEUS Partition Manager..some how when formatting earlier i had changed it from primary to logical,so had to switch it back to primary,now its working,,,
What if i say that solution to your problem is here .... The best answer is Remo Recover Windows Free application, it will resolves all your problem with just few mouse click steps... so you can try with it....
Seems like SPAM to me !!!!
His sd-card probably is going bad !
No doubt. Spam for sure. I've had this phone for a long time and never heard of anyone using it. How's a Windows recovery tool gonna save an Android? I'm interested now. :D
