Please help
There is still no definitive proof that your Google One backups aren't working properly. I won't repeat the explanation about backups I wrote previously but in simpler terms, it sounds like Google One is doing what it's supposed to do.
I'll suggest it would be less frustrating to just stop fixating on things that you don't want to educate yourself on how they function. Your assumption that a backup utility should waste time and resources copying data that's already in a previous backup isn't practical. In your case, it's not a reality that all 239 of your apps are being updated and/or altered in between each backup session. So if there's no change with an app that is already in a previous backup, why waste time backing it up again for no reason? Apps that do get updated involve changes in their code base so those should be backed up.
I agree, but the problem with Google one, is that it deletes previous backups. Si I had a successful backup of all of my apps last month, but it deleted it and did another one, which is incomplete.
I'd stop worrying about how often you restart your phone
Seems he's already done that. So if the problem was that the phone needed to be restarted, that problem likely would have been solved by now.
nor doing a Factory Reset
It's good to do a factory reset once every few years anyway (so long as you have your data properly backed up and all). Errors and problems can build up in the operating system (OS) over time. That's why when someone needs help, my first question is how long it's been since he's reinstalled the OS. If it's about time to reinstall the OS (reset the phone), he may as well do that since it ought to be done anyway. And it might just fix the problem.
In short: When you've run into a computer problem (and smartphones are computers), that's a good excuse to perform routine maintenance. Routine maintenance that ought to be performed anyway is often enough to fix the problem.
and especially not flashing your phone with a new ROM (that's how one installs a new, clean Android operating system).
I would not advise installing a new Android distribution, that is, a custom ROM! Not yet anyway. That's an extreme measure, and it may do far more harm than good.
Wish I could help you, but I can't.
Yeah sometimes I do not use my Google one to back up everything even in the apps, they are mostly from my f-droid a few of them and a slight major does come from Google Play though... 239 apps, wow.. I have around 100 of them.
What does it mean when the OP just posts a comment that's empty and just quoting other comments? I see this same thing happen on Reddit as well and I don't get it.
I never wanted it. I don't do the whole 'life as a service' subscription garbage. That stuff adds up real quick. But I still get notified by it (Apparentlly built in modern android) being used to backup my photos via a notification I haven't been able to turn off yet.
