Help Please help!
I tried to reflash but now it gets stuck in the part when it says GT-I5800
and samsung below but it wont go any further i think it froze...
So what should I do? I dont care about froyo anymore i just want my phone to work...
well...which rom did u flash?
If u flashd JPB then its probably the issue with datafs.rfs cos JPB doesnt have that...I would suggest you to wipe off your data from recovery and then flash a rom with datafs.rfs (e.g. DDJG6) and then try JPA or JPB..
I think this would help you. :)
