Root please help
Status
Not open for further replies.
Hi im new to this and am trying to do step 4 of the [GUIDE] Rooting Procedure Step by Step
"Immediately install a Custom Recovery.
This following recovery will work on various phones and various Android versions.
All In One Recovery Thread
Once that is successfully installed you can NOW click on AnReboot and choose Reboot Recovery.
Once recovery is loaded, use your volume down key to scroll to - Backup/Restore.
Hit your phones Menu key.
Then scroll down to - Nand Backup + .android_secure and hit your Menu key to confirm.
This NAND backup will be your system restore point and will save your butt if you make a mistake later."
im lost is there a app to install to? there is no step by step on how to install a custom recovery.
please help
Status
