Please help!
  • Thread starter Thread starter doxiemomma87
  • Start date Start date
D
doxiemomma87
Guest
So I downloaded some apps that are paid from amazon and then I got a new phone. How do I get those apps I paid for on my new phone:confused: I still have the email conformation that says I bought them. Any help is greatly appreciated!
Hi
The apps are linked to your gmail account so as long as you link your new phone to that same gmail account your apps will be waiting in Market in "my apps" for you to re-download.
Gg
APOLOGIES: Just noticed you said Amazon not Market so this doesn't work for you :(
All you should have to do is download Amazon appstore to your new phone and log in with the same email and password as the old phone and the apps should be there to download in the "my apps" section.
Well that didnt work. Maybe because I bought the apps through my computer and had them instantly sent to my phone? I dont know?
You would think that there would be a way to "resend" The app to your phone when you buy it from amazon.
Hmmm .. in theory it should work as it's all cloud technology. Fingers crossed someone else may have had a similar issue and can help you resolve.
Ok got it figured out. I had to install amazon app store application to download them all again :) The problem was I was trying to get them from the regular market. Thanks for the help everyone!
No, the apps you get from Amazon are separate from the ones you get from the market. If you download them from one place you can't re-download or update from the other.
