Root Please help!!!
hYpHyPuRpLe
My phone was working fine but as soon as I got admiral beast running my phone wont connect to my computer. It will connect to transfer files but it wont connect for developing purposes. I've already uninstalled the drivers and restored my phone multiple times but it still wont connect. I get the icon on my status bar to connect to transfer files but it wont give me the usb debugging icon. Any ideas? Thanks in advance. (My brothers admire also won't connect and neither will my friends Esteem. I've also tried on another computer and a lot of different cables.)
I Kind of had the same problem, dont know what it is but for me Usb Dunging is there and sorry for the spelling but its just want show for some reason, when i installed cwm It didnt show but the installation still went through is yours something like this and if not my best advice is to ask mystery if it happened right after the installation, it may just be a small bug that need to be fixed
Hoped This Helped :p
Have you tried reinstalling the drivers again? I remember that happened to me after I did something. I dont remember if it was after I did the admiral beast or the cwm and my computer wasnt asking for drivers or anything but then I installed the drivers manually after I downloaded them from somewhere and it worked again....Ill try to remember and I soon as I do Ill repost with any info or links
Stupid question....
Is USB debugging enabled?
Change Log:
Initial Release - V.01
Rom/Theme Flasher - Shabbypenguin
Themed, Zipalighned, Png Optimized Framework-res.apk, Systemui.apk, Swype.apk
Added new ringtone
Added new notification tone
Force home app to ram
Data/network tweaks
Changed call ring delay
Enabled Stagefright media
Lowered dalvik vm heapsize
Disable ad debug icon in notifiaction bar
Changed wifi scan interval ( less scans better battery )
Other battery enhancement tweaks
Tweaked UI
your usb debugging should still work.
The drivers are in the Odin thread and the cwm thread.
I found pdanet drivers are handy to keep too.
Oh yea, thats right. Then it did happen to me after cwm and I should have thought about that too, about the usb debugging. Sometimes the simple things is all it is.
thanks for helping guys yesterday when i got home from school i plugged it in and it worked... i have no idea why or how but it did. Thanks for helping!
