Help please help!!!
angoli
My droid 4 froze last night, so on 80% battery i pushed the power and down key to reboot. when i started it back up, the dual core comes up, and the droid saying... but sticks at the red logo. it stayed like that for over an hour... reboot again, same result. what can i do to fix this?
you can try to boot into recovery to do a factory reset . If that doesn't help then you will need to take it into a store to see if you can get it swapped out . Are you rooted? Have you done anything devices you think they have caused this recently?
