Please help.....
markie44
I don't know how to create an icon for the music app for my galaxy s3. I go to app manager/ all apps and I see the app but there is nothing there to create a shortcut icon on a page. When I go to apps icon it does not appear. Nor in Widgets. I see in files where my downloaded songs are under the play music app, but I don't see any way to get the icon on a page. I'm sure there's an easy way but I'm just not well versed with smart phones. I googled the problem to no avail. Thank you for any suggestions.
I cant remember how to do it on the s3 but on your home screen, try long-pressing on an empty area and see if it gives you an option to choose an app :thumbup:
I think you will find a number of different player widgets to choose from. Some are small and some are full page. Be sure to have a full screen available if you want the bigger player. Have fun.
Why would you go to the App manager? Just look in your app drawer and it should be there. Then press and hold the music player icon and don't release it until the drawer disappears and you're in a free spot then let go.
Thank you for your advice. Heat57 there is no icon for music in my app drawer. When I press on apps it gives me the apps ive downloaded and a some more, but there is no music icon at all. 2 other people have looked there as well. Thank you
