Root Please help!!!!!!!!!!!!!!!!!!
coop3r314
Okay I have :
htc evo design 4g boost
kingdom
hboot 1.32.0000
radio 1.11.00.1116
emmc-boot
I am currently relocked and stuck in hboot loop.
I rooted and was running cwm and could not activate throught boost, so i un rooted and relocked my bootloader but now i cannot flash anything, i have tried every ruu installer i could find and tried every stock image and It either scans the img on hboot and then does absolutely nothing, or during the ruu installer is fails at the CID check everytime and i have tried at least 5 or 6 different ruu installers, what the hell am i doing wrong, or is there a cwm rom that works with boost please help asnap!!!
Okay I have :
kingdom
hboot 1.32.0000
radio 1.11.00.1116
emmc-boot
First off try unlocking your bootloader again, if you run a RUU while its unlocked I think it locks itself or has a soft brick or something like that, just unlock it again and if you cant get to CWM try flashing the CWM Recovery IMG via Fastboot. Hopefully it works! :smokingsomb: need anything just ask! :)
Well I hope u get unbricked.
Unlock bootloader and flash ur cwm recovery back
Flash your rom back.
Use a rom that is baised on boost stock.
Now if the phone was acrivated before it must be removed from that account not just forgoten about if it is still on the old account it must be removed.
Now once that is done activate it.
Now once that is done go to about phone I belive and look for somthing called "update profile" hit that.
Should get u up and running.
Least thats how straight talk cdma works. I always haft to flash arearom [boost based] and update the profile when reactivating then flash back to cyogenmod.
Once profile is updated you can run any rom uou wish.
As for unbricking, I cant help you, never played with this phone.
