Help Please help???
Sup guys all of the sudden on my note 3 running 4.3 I started getting this error on every pic and video I take??? I can see everything on my memory card except for everything from the last few days. Any got any ideas?
Might sound silly, but I'd try a reboot, pulling the battery first. It's fixed a few things in the past. Hope you get it sorted out.
Are you sure your phone didn't do an update to 4.4 while charging...I have heard of issues with camera and video and sd card storage after update...if problem not solved after reboot you may have to call provider and or do a factory reset.
Copy and paste everything off your memory card as a matter of urgency to a PC and upload it to Google Drive (or other cloud storage). Then if you really really need to keep these photos an external hard drive and yet another cloud storage can't hurt. Precious memories cannot be gotten back easily if they were stored digitally in one place and it goes kaput, I know from bitter experience. It does look as if your memory card is failing to me. I hope I'm wrong.
My memory card developed the same problem. You could read all the files that had already been written to it, up to a certain day, but you couldn't add anything else to it or make any changes to it otherwise. And no, it wasn't full! ;)
I confirmed the card was bad by taking it out and trying to format it and all those others things directly when plugged into a PC. Same behavior. SanDisk agreed to replace it for me. In the meanwhile, I put a smaller memory card into my N3 to handle taking pictures until my replacement 64GB card from SanDisk arrives.
