Help please help !
so I got this Samsung galaxy tab 3 0.7 for Christmas and after a couple months I locked myself out and its asking me for the email and password but I've tried all the email addresses nothing seems to work and I know that my emails work because I use them !! any suggestions ? I would really appreciate it.:)
Hi
Probably the problem is that your tablet has no data connection. The email and password cannot work without one. I think your only option will be to do a factory reset. (Hope you have your data backed up.....) Unfortunately, if it is off, you can't turn it on when you are locked out. If you happen to have usb debugging (in settings) enabled there may be a way - do post back.
