Help Please Please Please Help!!!
my sister's tab freezes this morning with no response, I restarted it manually but it started to give me many Force Close errors. I thought the factory reset will fix it but nothing happens I tried everything.
wiping the data, doing factory reset and flashing the stock firmware, it says that the format is successful but it won't delete or format anything from the tab.
When i flash the firmware every thing went fine but after the booting i get so many force closes then I end up with the old firmware with all the Apps and the settings, believe me every firmware I flash goes without any errors but when I load up the system everything is the same even her wallpaper. I know it's weird but Please I really need help !
EDIT : I tried to flash Froyo back the flash process went fine but after boot i got the same Force Close errors with my settings and my applications the same but the system is Froyo.
What I want to say that it successfully flashed the firmware but there is something prevent it from format or wipe the data and the internal memory.
I hope you find a solution.
