Please share your battery stats
shodoc
Hi,
First time poster but have been a long time lurker of this forum and I am pleased to be a member of this forum .
Received my new s4 active last week and I feel that my s4 active battery life is not that great. Could you all post your battery stats using Battery HD app, so I can compare the battery stats and also others could use it as reference, thanks:
My battery stats are as follows:
BATTERY HD APP::
100% charge
-standby: 125 hrs
-music playback: 19h52min
-video: 13h 13min
-net browsing
- wifi: 9:37
- mbile: 3:56
-talktime:
3g/4g: 7:05
Hi,
BATTERY HD APP::
100% charge
-standby: 125 hrs
-video: 13h 13min
-net browsing
- wifi: 9:37
- mbile: 3:56
-talktime:
3g/4g: 7:05
Huh? Are you getting these from the phone or from actual use? I'd suggest that you note ACTUAL usage stats to compare to your OWN use. Everyone is different, we all use different features/functions in different areas. So many things affect use and time. Where are you? How strong is the signal. Screen brightness; auto 100% 50%? Auto sync email, FB, Twitter, INstagram, etc. What are you using the phone to do? Real data SO much better than "so called stats" from an app.
Hi, this is the battery stats according to Battery HD after I charge it to 100 %. Are the times shown by this app just a general estimate or is it specific to the battery condition of the device (meaning the time will vary with conditon of the battery)?
_______________________________________________________________________
The actual battery drain I notice in standby with
-Wifi- on
- location services on - on
-screen- auto
- signal- 3 bars
Standby after 1 hour, the battery drains about 2-3 percent/hour... does this sound normal?
After asking around, it was brought to my attention that the S4 Active use a TFT screen where an S4 uses a Super Amoled screen among other hardware differences. This technical difference is likely to have significant impact on batter life overall so I think the OP will actually be better off in the Active forum.:)
Hi,
BATTERY HD APP::
100% charge
-standby: 125 hrs
-video: 13h 13min
-net browsing
- wifi: 9:37
- mbile: 3:56
-talktime:
3g/4g: 7:05
I would suggest installing snapdragon guru.
