Trickster03
I apparently flashed a bad ROM or somthing, But then I tried the recover keys. And It worked into CWR 3.0.0.4 Then It was hooked up to the PC so I tried to update it really quick to CWR 3.0.2.4 Then It said it did it successfully then restarted and then I was stuck on Boot Screen The white "Huawei" Screen Then it just stays there. The lights come on and everything, Then I tried to get back into Recovery mode, And it woulent do it So I kept trying and trying then It said "Firmware Update" "1/2" "Update Failed!" Then freezes on that screen. Then I tried to get into recovery a few more times after that, And it still showed that screen "Updated Failed" But now It won't even show that, Won't boot into recovery or anything I'm doing (Power+VolDown+GreenButton) Even tried different ones still locks up at the "Huawei" Screen. I even tried loading Some update.zip files to the Root of my SD Card. And tried loading into Recovery...Tried every variation of that..So I'm really out of ideas...Even took the battery out for 5-10 min then tried. Etc. Still won't get past that White Huawei screen...If anyone has any other ideas on what I can do please share...And by the way, It won't show up on Android Commander or on the PC at all And I have to take the battery out for the screen to stop. So it just hangs at that screen, It won't reboot or anything If I press the power button long enough it will but it doesn't reboot on its own. Just trying to give as much info as possible. :/
/WHEW
