pleaseee helpp mee !!!!
how to transfer all your applications ( apps , games , etc) from internal memory to sd card !!!!!!????? WITHOUT ROOTING AND THE EASIEST WAYYY
PLEASE HELP ME !!!! Ohh i forget i have samsung galaxy mini
Applications - downloaded - tap on app and follow steps to move to sd card. Also, there is an application called Apps 2sd card that you can installed that will allow you to do the same.
Hello and welcome aboard. :)
isnt working i cant move all apps , that app just tell me what applications are in my phone and on my sd card not to move themm
...then follow the steps above.
Note: Some widgets will not function properly when stored on the sd card. Since this is the Intro section - checking inside your device's area of support would be better able to assist you further.
Best fo luck.
Best fo luck.
nooo again i cant any other way pleaseee ?!!!!
if the app doesnt allow it to be moved to the sd card then you would need to root in order to move it to the sd card.
however in such cases it still doesnt work, and can result in issues with the app itself.
it is a good idea to give us an idea of what cell phone you have, we can point you to the people that will be glad to help you
Moving apps to the SD card only moves a portion on the files. A lot of stuff (including the app data and cached files) will remain on the internal storage.
okkk i have samsung galaxy mini and i dont want to root because i heard that a lot of people have got a lot of problems i just wanna now if its a way to transfer apps from my phone to sd card ????!!!!!
i noww that but if i transfer apps to sd card more space will be left and if the space its full i will delete the data and cache !!!!!!
there are 2 types of samsung galaxy mini's
S5570 GSM - international
SGH-T499V - T-Mobile
i am under the impression you are not in the states, and have an international carrier.
but i will not direct you to the wrong one. The problem with moving these apps is that there are some that are not allowed to be moved. there is nothing we can do about that except contact the developer of the apps.
rooting you can move the majority of them, but as we have explained it can, and might cause problems and functionality with the app.
rooting doesnt cause problems, all rooting does is give you full access to your phone. rooting will not cause any damage to your phone in any way. it does void the warranty, but you can easily unroot if you need to.
Moving apps to the SD card doesn't always help. In my case I have plenty of space on /data/apps (which is where a lot of stuff is stored) but very little on /data/data - which is a pain because files in that partition don't get moved with any form of App2SD. Even worse is that this partition can contain large application lib files which contribute to low space warnings but cannot be resolved without uninstalling the app.
thanks i will root my phone
