Dear Friends... I was using IGOR Fast Notepad... It was a good apps.. But.. When I reinstall my ICS in SE XPERIA ARC S. I downloaded the notepad again... All my previous files shows #decrypt error.... I msgd Igor... No use... Pls help as I saved a lot of notes from class which is important... Thanking you all in advance...
Pls do help.. Is there anyway I can encrypt using any software....
