pls help, galaxy w camera error!
Hello and welcome aboard. Thanks for joining us here. ツ
What I would suggest you do, is to clear data from the camera application. Tap settings ⇨ then downloaded or storage use (depending on your device model) and clean "data" from the camera app.
I hope this helps!
i am using a GALAXY W. i always received a cannot connect to camera.
Did you do what was suggested? Either do that are reset the device. If neither one works, then you might have to get the device repaired or replaced.
Good luck.
