Help plz help me guys
d07a2010
i've bought se live with walkman w19i for 2 days and facing 2 problems on it
i want to use my phone as modem so that can surf the internet on my lap by 3g
(HSDPA 7.2 Mbps), but i searched in google and can't find anything helping me and don't need tethering internet option or wifi hotspots feature but i want to share my 3g connection as a modem to my laptop but pc companion doesn't have any modem driver installed and can't use sony pc suite also.so plz help me.
i finally found a program (BlueDun 1.14) that's not exact i need but it can satisfy me now but this program connected successfully as wifi and shared to mylaptop but can't connect with 3g coverage H that thing exact i want it .
when i using this program as wifi it install a new modem (bluetooth dun modem) on my laptop that exact i need but with usb cable and 3g not wifi that's my 1st problem.
My 2nd one is when i connect to 3g it cuts in browsing and some more application can't start on 3g and tells me there's no intenrnet connection found so my question is that Is there a program to prevent cut or disconnecting automatic continuous and make smoothly connection to all applications on my phone (LAN Card)???...thanks and sorry for my bad english as i'm egyptian.
:D I got a solution to your problem 1:
Follow :
1. Turn on 3G/2G data on your phone
2. Connect your phone to your laptop via USB
3. On your phone : Go to Settings>Wireless & networks>Tethering & portable hotspot>
4. Check mark USB tethering
5. Your PC will automatically install necessary drivers and tethering will begin !
(I myself tested this method and it worked!)
(NOTE:You may need internet connection from other sources while installing drivers)
As far as 2nd problem is concerned, try reporting it to SONY service center.
And yes, your English is not that bad!
thank you for replying 2 fast and i've just try your solution before and tried it now and print screen to you the problem is that when tetherning successful connected i can surf internet over mobile but on lap the ping is requested timed out when browsing and unreachable when stop browsing, hope u find solution pro,thanxxx again.
thanks for ur reply again
but i've win 7 x64 also the problem persists on it plz i want from professionals to reply me
thanks i get finally my problem solved and the prb was from apn data provider all my problems in that awesome phone cleared except one problem and it's be perfect and ideal.
the prb is that how to use it as a modem not for sharing internet no i mean i want to have two connections independent themselves one connection on laptop and another connection on my phone as all mobiles in the world can do it that's not a miracle,so helping me experters,thanks alot.
