Pocket Dials and Unlocking
Eldogg
I just got a Samsung Galaxy S3 to replace my Motorola Droid Razr Maxx. I have had many phones and blackberries. But I have never had so many issues with the phone unlocking, switching from vibrate to sound, and pocket dialing people with any other phone ... this one seems much much worse.
Has anyone had such issues and if so, any suggestions? Thanks in advance.
One thing that will help with unlocking/pocket dialing is to go to Menu>System Settings>Lock Screen. Check the box for "Lock instantly with power button, and choose "Immediately" under Lock Automatically.
Not sure if there is an stock option to disable the volume buttons when locked, but I use Widget Locker and it allows me to disable volume buttons unless I'm listening to music when locked.
My volume buttons don't get activated while locked with the stock swipe locking option. What I do is, I would always lock my phone with the button on the right before I place it down or in my bag or pocket. It still somehow pocket dials off and on but it's rare. I didn't change anything in the lock screen menu, I'm just using the default settings. Eh.. Mine doesn't even give me "lock instantly with power button" option, now that I check... :/
I do the same thing. Yet it keeps on unlocking somehow and pocket-dialing. I have never had a phone so sensitive like this.
hmm try setting it on a different locking option, for example a pin code or a password or even a pattern under settings > my device > lock screen > screen lock
I do use a pattern lock, so maybe that is only an option when you have a pattern/PIN set... Maybe try a simple pattern for a while and see if that helps.
I will look into pattern lock. But I have to tell you ... this morning, I had an unintentional dial appear right before my eyes while I was holding the phone and unlocking it ON PURPOSE to be able to use it. There is no doubt in my mind that there is something wrong with the phone.
wait so...
the phone was dialing right before you as you unlocked it?
think I misunderstood that.. but if that's the case, that is some phantom phone lol.... unless it has something to do with motions.. which I don't use cause it drains battery like mad :/
wait so...
No, it started right after I unlocked it. I'll look into motions but don't think I have them enabled. Thanks.
