Root Point me to right Rom
erik077
Question first; I have rooted evo with stock 2.2 (3.70) and dont know should I use only rom based on same software version (3.70)?
Here is what I need ; navigation, 4G, sprint tv, wireless tether (and good battery life). What rom should be good for me? Friend point me to one but then my navigation and sprint were gone so I had to restore my backup (stock). Does Myns have those stuff and will fit me? Give me 3 or 4 rom that will work for me (have mentioned stuff) so I can try them out.Thanks in advance.
Ps. Want to move blockbuster, amazon, nova & kindle.
Many of the ROM developer include the applications that they deleted from the ROM in a folder that you can access so you can reinstall the applications if you want. I believe both Fresh and Myns ROMs do that.
Does that one have 4 stuff I mentioned? It says sprint tv is removed.
Hope someone will give couple of them to test and chose. Thanks fgcchevi
Fresh has an app called ES File Explorer. In that app there is a folder called fresh removed, all the removed apps are in there, and can easily be installed. You need to go to your settings, applications and check install from unknown sources to install the sprint tv app.
As I said, I to am new to rooting, but from what I understand myns Rom is based off of the old build. In order to use myns Rom I believe u would have to flash the older radios also, as I think you have the newest radios. Maybe somebody with a little more knowledge can chime in, as i said I am also a noob.
