Simon_Gardner
Android Expert
I now have a partial answer to my long-standing beef with my first smartphone - the Note 3. Yes it's that appalling radio performance compared to every dumb phone I've had. This meant the Note 3 only half worked "as a phone" in my home. Just so long as the wind was blowing the right way.
A few days ago I installed a GBP 100 (US$ 170) femtocell offered by my service provider [uniquely in the UK since the only other provider which did them here has stopped since a merger (?)]. Some other providers in other countries offer these.
This gives what is effectively a mini cellular mast in my home which communicates with the rest of the network via my broadband. This is not Skype or any other VoIP but you just use your phone/text incoming/outgoing as normal. Only phones you specify can be used on it so nobody nearby is going to be using it. Range is supposed to be about 30m. Looks to be that too.
For the last few days I've been getting full bars on my Note 3 and it's now useable anywhere in the house.
After the capital outlay, I'm not charged anything more although the phone calls are billed as normal to my account as if they had been made using a regular mast.
Works for me.
Works for me.
