Hi All,
I am new to android development, I have a listview which is populated dynamically from an external xml file stored on wamp server which is working fine.
However, am having difficulty pushing the items on the list into the expandable listview.
Any help will be appreciated.
The code for the listview is:
the code for the expandable list is:
Bascically what I want to do is to push the name and score in the listview to the details primary sales rep sections of the Expandable
Code:
package com.pxr.tutorial.xmltest;
import java.util.ArrayList;
import java.util.HashMap;
//import mCRM.android.hp.Contacts1;
import org.w3c.dom.Document;
import org.w3c.dom.Element;
import org.w3c.dom.NodeList;
import com.pxr.tutorial.xmltest.R;
import android.app.ListActivity;
import android.content.Intent;
import android.os.Bundle;
import android.view.View;
import android.widget.AdapterView;
import android.widget.AdapterView.OnItemClickListener;
import android.widget.ListAdapter;
import android.widget.ListView;
import android.widget.SimpleAdapter;
import android.widget.Toast;
public class Opp_level0 extends ListActivity {
/** Called when the activity is first created. */
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.listplaceholder);
int id = getIntent().getIntExtra("id", 0); ///rem
ArrayList<HashMap<String, String>> mylist = new ArrayList<HashMap<String, String>>();
String xml = XMLfunctions.getXML();
Document doc = XMLfunctions.XMLfromString(xml);
int numResults = XMLfunctions.numResults(doc);
if((numResults <= 0)){
Toast.makeText(Opp_level0.this, "Geen resultaten gevonden", Toast.LENGTH_LONG).show();
finish();
NodeList nodes = doc.getElementsByTagName("result");
for (int i = 0; i < nodes.getLength(); i++) {
HashMap<String, String> map = new HashMap<String, String>();
Element e = (Element)nodes.item(i);
map.put("id", XMLfunctions.getValue(e, "id"));
map.put("name", "Account Record: " + XMLfunctions.getValue(e, "name"));
map.put("Score", "Subrecord: " + XMLfunctions.getValue(e, "score"));
mylist.add(map);
ListAdapter adapter = new SimpleAdapter(this, mylist , R.layout.opp_level0,
new String[] { "name", "Score" },
new int[] { R.id.item_title, R.id.item_subtitle });
setListAdapter(adapter);
final ListView lv = getListView();
lv.setTextFilterEnabled(true);
lv.setOnItemClickListener(new OnItemClickListener() {
public void onItemClick(AdapterView<?> parent, View view, int position, long id) {
@SuppressWarnings("unchecked")
HashMap<String, String> o = (HashMap<String, String>) lv.getItemAtPosition(position);
Toast.makeText(Opp_level0.this, "Record '" + o.get("id") + "' was clicked.", Toast.LENGTH_SHORT).show();
if(id==0){
Intent myIntent = new Intent(view.getContext(), opp1.class); // when a row is tapped, load tes.class
startActivityForResult(myIntent, (int) id); // display tes.class
else if (id==1){
Intent myIntent = new Intent(view.getContext(), opp2.class); // when a row is tapped, load tttt.class
startActivityForResult(myIntent, (int) id); // display tttt.class
Code:
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]package[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2][COLOR=#7f0055]
[LEFT][/COLOR][/SIZE][SIZE=2]com.pxr.tutorial.xmltest;[/SIZE][/LEFT]
[LEFT][SIZE=2][COLOR=#3f7f5f][SIZE=2][COLOR=#3f7f5f]//package mCRM.android.hp;[/COLOR][/SIZE][/COLOR][/SIZE][/LEFT]
[/COLOR][/SIZE]
[LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]java.util.ArrayList;[/SIZE][/LEFT]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]java.util.HashMap;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]org.w3c.dom.Document;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]org.w3c.dom.Element;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]org.w3c.dom.NodeList;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]com.pxr.tutorial.xmltest.R;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]android.app.ExpandableListActivity;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]android.content.Intent;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]android.os.Bundle;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]android.view.ContextMenu;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]android.view.Gravity;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]android.view.MenuItem;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]android.view.View;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]android.view.ViewGroup;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]android.view.ContextMenu.ContextMenuInfo;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]android.widget.AbsListView;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]android.widget.AdapterView;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]android.widget.BaseExpandableListAdapter;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]android.widget.ExpandableListAdapter;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]android.widget.ExpandableListView;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]android.widget.ExpandableListView.OnGroupClickListener;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]android.widget.ListAdapter;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]android.widget.ListView;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]android.widget.SimpleAdapter;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]android.widget.AdapterView.OnItemClickListener;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]android.widget.ExpandableListView.OnChildClickListener;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]android.widget.TextView;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]android.widget.Toast;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]android.widget.ExpandableListView.ExpandableListContextMenuInfo;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]import [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]android.widget.SimpleExpandableListAdapter;[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]public [/COLOR][/SIZE][/COLOR][/SIZE][/B][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]class[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] opp1 [/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]extends[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] ExpandableListActivity [/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]implements[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] OnChildClickListener { [/SIZE]
[LEFT][SIZE=2]ExpandableListAdapter [/SIZE][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]mAdanna[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]; [/SIZE][/LEFT]
[LEFT][SIZE=2][COLOR=#646464][SIZE=2][COLOR=#646464]@Override[/COLOR][/SIZE][/COLOR][/SIZE]
[LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]public [/COLOR][/SIZE][/COLOR][/SIZE][/B][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]void[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] onCreate(Bundle savedInstanceState) { [/SIZE][/LEFT]
[/LEFT]
[LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]super[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2].onCreate(savedInstanceState); [/SIZE][SIZE=2][COLOR=#3f7f5f][SIZE=2][COLOR=#3f7f5f]// Set up our adapter [/COLOR][/SIZE][/COLOR][/SIZE][/LEFT]
[SIZE=2][COLOR=#3f7f5f][LEFT][SIZE=2][COLOR=#3f7f5f]//setContentView(R.layout.opppp);[/COLOR][/SIZE]
[LEFT][/COLOR][/SIZE][SIZE=2]ExpandableListAdapter mAdanna; [/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]final [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]ExpandableListView epView = (ExpandableListView) findViewById(R.id.[/SIZE][I][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]expandableListView1[/COLOR][/SIZE][/COLOR][/SIZE][/I][SIZE=2]);[/SIZE][/LEFT]
[/LEFT]
[LEFT][SIZE=2]mAdanna = [/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]new[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] MyExpandableListAdapter();[/SIZE]
[LEFT][SIZE=2]epView.setAdapter(mAdanna);[/SIZE][/LEFT]
[/LEFT]
[LEFT][SIZE=2][COLOR=#3f7f5f][SIZE=2][COLOR=#3f7f5f]//setListAdapter(mAdanna); [/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][COLOR=#3f7f5f]
[LEFT][/COLOR][/SIZE][SIZE=2]registerForContextMenu(getExpandableListView()); [/SIZE][/LEFT]
[/LEFT]
[LEFT][SIZE=2]ArrayList<HashMap<String, String>> mylist = [/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]new[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] ArrayList<HashMap<String, String>>();[/SIZE][/LEFT]
[LEFT][SIZE=2]String xml = XMLfunctions.[I]getXML[/I]();[/SIZE]
[LEFT][SIZE=2]Document doc = XMLfunctions.[I]XMLfromString[/I](xml);[/SIZE][/LEFT]
[/LEFT]
[LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]int [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]numResults = XMLfunctions.[I]numResults[/I](doc);[/SIZE][/LEFT]
[LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]if [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]((numResults <= 0)){[/SIZE][/LEFT]
[LEFT][SIZE=2]Toast.[I]makeText[/I](opp1.[/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]this[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"Geen resultaten gevonden"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], Toast.[/SIZE][I][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]LENGTH_LONG[/COLOR][/SIZE][/COLOR][/SIZE][/I][SIZE=2]).show(); [/SIZE]
[LEFT][SIZE=2]finish();[/SIZE]
[SIZE=2]}[/SIZE][/LEFT]
[/LEFT]
[LEFT][SIZE=2]NodeList nodes = doc.getElementsByTagName([/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"result"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]);[/SIZE][/LEFT]
[LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]for [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]([/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]int[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] i = 0; i < nodes.getLength(); i++) { [/SIZE][/LEFT]
[LEFT][SIZE=2]HashMap<String, String> map = [/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]new[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] HashMap<String, String>(); [/SIZE][/LEFT]
[LEFT][SIZE=2]Element e = (Element)nodes.item(i);[/SIZE]
[LEFT][SIZE=2]map.put([/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"id"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], XMLfunctions.[I]getValue[/I](e, [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"id"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]));[/SIZE]
[SIZE=2]map.put([/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"name"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"Account Record: "[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] + XMLfunctions.[I]getValue[/I](e, [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"name"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]));[/SIZE]
[SIZE=2]map.put([/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"score"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"Subrecord: "[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] + XMLfunctions.[I]getValue[/I](e, [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"score"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]));[/SIZE]
[SIZE=2]mylist.add(map); [/SIZE]
[SIZE=2]} [/SIZE]
[SIZE=2][COLOR=#3f7f5f][SIZE=2][COLOR=#3f7f5f]/*[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][COLOR=#3f7f5f]
[SIZE=2][COLOR=#3f7f5f]ExpandableListAdapter adapter = (ExpandableListAdapter) new SimpleAdapter(this, [U]mylist[/U] , R.layout.opppp, [/COLOR][/SIZE]
[SIZE=2][COLOR=#3f7f5f]new String[] { "Details" }, [/COLOR][/SIZE]
[SIZE=2][COLOR=#3f7f5f]new [U]int[/U][] { R.id.expandableListView1});[/COLOR][/SIZE][/COLOR][/SIZE][/LEFT]
[/LEFT]
[/COLOR][/SIZE]
[LEFT][SIZE=2][COLOR=#3f7f5f][SIZE=2][COLOR=#3f7f5f]setListAdapter(adapter);[/COLOR][/SIZE][/COLOR][/SIZE][/LEFT]
[/COLOR][/SIZE]
[LEFT][SIZE=2][COLOR=#3f7f5f][SIZE=2][COLOR=#3f7f5f]*/[/COLOR][/SIZE][/COLOR][/SIZE][/LEFT]
[/COLOR][/SIZE]
[LEFT][SIZE=2][COLOR=#3f7f5f][SIZE=2][COLOR=#3f7f5f]///----------------this is where my problem lies----------------------------//////////[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][COLOR=#3f7f5f]
[LEFT][/COLOR][/SIZE][SIZE=2]epView.setOnGroupClickListener([/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]new[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] OnGroupClickListener(){[/SIZE][/LEFT]
[/LEFT]
[LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]public [/COLOR][/SIZE][/COLOR][/SIZE][/B][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]boolean[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] onGroupClick(ExpandableListView arg0, View arg1, [/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]int[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] groupPosition, [/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]long[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] arg3){[/SIZE]
[SIZE=2][COLOR=#646464][SIZE=2][COLOR=#646464]@SuppressWarnings[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]([/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"unchecked"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2])[/SIZE]
[SIZE=2]HashMap<String, String> o = (HashMap<String, String>) epView.getItemAtPosition(groupPosition); [/SIZE]
[SIZE=2]Toast.[I]makeText[/I](opp1.[/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]this[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"Record '"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] + o.get([/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"id"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]) + [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"' was clicked."[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], Toast.[/SIZE][I][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]LENGTH_SHORT[/COLOR][/SIZE][/COLOR][/SIZE][/I][SIZE=2]).show();[/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]if[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2](groupPosition == 0){[/SIZE]
[SIZE=2][COLOR=#3f7f5f][SIZE=2][COLOR=#3f7f5f]//o.p[/COLOR][/SIZE][/COLOR][/SIZE]
[SIZE=2]o.[U]get[/U]([/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"name"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]);[/SIZE][/LEFT]
[SIZE=2]}[/SIZE]
[LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]return [/COLOR][/SIZE][/COLOR][/SIZE][/B][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]true[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2];[/SIZE]
[SIZE=2]}[/SIZE]
[SIZE=2]});[/SIZE]
[SIZE=2][COLOR=#3f7f5f][SIZE=2][COLOR=#3f7f5f]/////----------------------------------end----------------------------------////////// [/COLOR][/SIZE][/COLOR][/SIZE][/LEFT]
[/LEFT]
[/COLOR][/SIZE]
[LEFT][SIZE=2]} [/SIZE][/LEFT]
[LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]public [/COLOR][/SIZE][/COLOR][/SIZE][/B][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]void[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] onCreateContextMenu(ContextMenu menu, View v, ContextMenuInfo menuInfo) { [/SIZE][/LEFT]
[/LEFT]
[LEFT][SIZE=2][COLOR=#3f7f5f][SIZE=2][COLOR=#3f7f5f]//menu.setHeaderTitle("Sample menu"); [/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][COLOR=#3f7f5f]
[LEFT][/COLOR][/SIZE][SIZE=2]menu.add(0, 0, 0, R.string.[/SIZE][/LEFT]
[/LEFT]
[LEFT][I][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]app_name[/COLOR][/SIZE][/COLOR][/SIZE][/I][SIZE=2]); } [/SIZE][/LEFT]
[LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]public [/COLOR][/SIZE][/COLOR][/SIZE][/B][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]boolean[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] onContextItemSelected(MenuItem item) { [/SIZE][/LEFT]
[/LEFT]
[LEFT][SIZE=2]ExpandableListContextMenuInfo info = (ExpandableListContextMenuInfo) item.getMenuInfo(); [/SIZE]
[LEFT][SIZE=2]String title = ((TextView) info.[/SIZE][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]targetView[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]).getText().toString(); [/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]int [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]type = ExpandableListView.[I]getPackedPositionType[/I](info.[/SIZE][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]packedPosition[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]); [/SIZE][/LEFT]
[/LEFT]
[LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]if [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2](type == ExpandableListView.[/SIZE][I][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]PACKED_POSITION_TYPE_CHILD[/COLOR][/SIZE][/COLOR][/SIZE][/I][SIZE=2]) { [/SIZE][/LEFT]
[LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]int [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]groupPos = ExpandableListView.[I]getPackedPositionGroup[/I](info.[/SIZE][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]packedPosition[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]); [/SIZE][/LEFT]
[LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]int [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]childPos = ExpandableListView.[I]getPackedPositionChild[/I](info.[/SIZE][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]packedPosition[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]); [/SIZE][/LEFT]
[LEFT][SIZE=2]Toast.[I]makeText[/I]([/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]this[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2], title + [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]": Child "[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] + childPos + [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]" clicked in group "[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] + groupPos,Toast.[/SIZE][I][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]LENGTH_SHORT[/COLOR][/SIZE][/COLOR][/SIZE][/I][SIZE=2]).show(); [/SIZE]
[LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]return [/COLOR][/SIZE][/COLOR][/SIZE][/B][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]true[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]; [/SIZE][/LEFT]
[/LEFT]
[LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]else [/COLOR][/SIZE][/COLOR][/SIZE][/B][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]if[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] (type == ExpandableListView.[/SIZE][I][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]PACKED_POSITION_TYPE_GROUP[/COLOR][/SIZE][/COLOR][/SIZE][/I][SIZE=2]) { [/SIZE][/LEFT]
[/LEFT]
[LEFT][SIZE=2]Toast.[I]makeText[/I]([/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]this[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2], title + [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]": Group "[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] + groupPos + [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]" clicked"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], Toast.[/SIZE][I][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]LENGTH_SHORT[/COLOR][/SIZE][/COLOR][/SIZE][/I][SIZE=2]).show(); [/SIZE]
[/LEFT]
[LEFT][SIZE=2]} [/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]return [/COLOR][/SIZE][/COLOR][/SIZE][/B][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]false[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]; [/SIZE][/LEFT]
[LEFT][SIZE=2][COLOR=#3f5fbf][SIZE=2][COLOR=#3f5fbf]/** * A simple adapter which maintains an ArrayList of photo resource [U]Ids[/U]. [/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][COLOR=#3f5fbf]
[SIZE=2][COLOR=#3f5fbf]* Each photo is displayed as an image. This adapter supports clearing the [/COLOR][/SIZE]
[SIZE=2][COLOR=#3f5fbf]* list of photos and adding a new photo. * */[/COLOR][/SIZE][/COLOR][/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]public [/COLOR][/SIZE][/COLOR][/SIZE][/B][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]class[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] MyExpandableListAdapter [/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]extends[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] BaseExpandableListAdapter { [/SIZE][SIZE=2][COLOR=#3f7f5f][SIZE=2][COLOR=#3f7f5f]// Sample data set. children[I] contains the children (String[]) for groups[I]. [/I][/I][/COLOR][/SIZE][/COLOR][/SIZE][/LEFT]
[/LEFT]
[I][LEFT][I][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]private [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]String[] [/SIZE][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]groups[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] = {[/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"Details"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"Primary Sales Rep"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"Contacts"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]}; [/SIZE][/I][/I][/LEFT]
[I][LEFT][I][SIZE=2]String[][] [/SIZE][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]children[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] = {{ },{ [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"Fill 5"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"Fill 6"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"Fill 7"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"Fill 8"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] },{ [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"Fill 9"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"Fill 10"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] }}; [/SIZE][/I][/I][/LEFT]
[I][LEFT][I][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]public[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] Object getChild([/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]int[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] groupPosition, [/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]int[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] childPosition) {[/SIZE][/I][/I][/LEFT]
[I][LEFT][I][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]return [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]children[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][groupPosition][childPosition]; [/SIZE][/I][/I][/LEFT]
[I][LEFT][I][SIZE=2]} [/SIZE][/I][/I][/LEFT]
[I][LEFT][I][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]public [/COLOR][/SIZE][/COLOR][/SIZE][/B][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]long[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] getChildId([/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]int[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] groupPosition, [/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]int[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] childPosition) { [/SIZE][/I][/I]
[LEFT][I][I][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]return[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] childPosition; [/SIZE][/I][/I]
[I][I][SIZE=2]} [/SIZE][/I][/I]
[I][I][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]public [/COLOR][/SIZE][/COLOR][/SIZE][/B][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]int[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] getChildrenCount([/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]int[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] groupPosition) { [/SIZE][/I][/I]
[I][I][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]return[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]children[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][groupPosition].[/SIZE][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]length[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]; [/SIZE][/I][/I]
[I][I][SIZE=2]}[/SIZE][/I][/I][/LEFT]
[/LEFT]
[I][LEFT][I][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]public[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] TextView getGenericView() { [/SIZE][SIZE=2][COLOR=#3f7f5f][SIZE=2][COLOR=#3f7f5f]// Layout parameters for the ExpandableListView [/COLOR][/SIZE][/COLOR][/SIZE][/I][/I]
[LEFT][I][I][SIZE=2]AbsListView.LayoutParams lp = [/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]new[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] AbsListView.LayoutParams(ViewGroup.LayoutParams.[/SIZE][I][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]MATCH_PARENT[/COLOR][/SIZE][/COLOR][/SIZE][/I][SIZE=2], 64); [/SIZE][/I][/I][/LEFT]
[/LEFT]
[I][LEFT][I][SIZE=2]TextView textView = [/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]new[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] TextView(opp1.[/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]this[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2]); [/SIZE][/I][/I]
[LEFT][i][I][SIZE=2]textView.setLayoutParams(lp); [/SIZE][SIZE=2][COLOR=#3f7f5f][SIZE=2][COLOR=#3f7f5f]// Center the text vertically [/COLOR][/SIZE][/COLOR][/SIZE][/I]
[i][SIZE=2]textView.setGravity(Gravity.[/SIZE][I][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]CENTER_VERTICAL[/COLOR][/SIZE][/COLOR][/SIZE][/I][SIZE=2] | Gravity.[/SIZE][I][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]LEFT[/COLOR][/SIZE][/COLOR][/SIZE][/I][SIZE=2]); [/SIZE][SIZE=2][COLOR=#3f7f5f][SIZE=2][COLOR=#3f7f5f]// Set the text starting position [/COLOR][/SIZE][/COLOR][/SIZE][/LEFT]
[/LEFT]
[LEFT][SIZE=2]textView.setPadding(36, 0, 0, 0); [/SIZE]
[LEFT][SIZE=2]textView.setId(23);[/SIZE][/LEFT]
[/LEFT]
[LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]return[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] textView; [/SIZE]
[/LEFT]
[LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]public[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] View getChildView([/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]int[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] groupPosition, [/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]int[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] childPosition, [/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]boolean[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] isLastChild,View convertView, ViewGroup parent) { [/SIZE]
[LEFT][SIZE=2]TextView textView = getGenericView(); [/SIZE]
[SIZE=2]textView.setText(getChild(groupPosition, childPosition).toString()); [/SIZE]
[/LEFT]
[LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]public[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] Object getGroup([/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]int[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] groupPosition) { [/SIZE]
[LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]return [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]groups[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][groupPosition]; [/SIZE]
[/LEFT]
[LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]public [/COLOR][/SIZE][/COLOR][/SIZE][/B][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]int[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] getGroupCount() { [/SIZE]
[LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]return [/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]groups[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2].[/SIZE][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]length[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]; [/SIZE]
[/LEFT]
[LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]public [/COLOR][/SIZE][/COLOR][/SIZE][/B][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]long[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] getGroupId([/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]int[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] groupPosition) { [/SIZE]
[LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]return[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] groupPosition; [/SIZE]
[/LEFT]
[LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]public[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] View getGroupView([/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]int[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] groupPosition, [/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]boolean[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] isExpanded, View convertView,ViewGroup parent) { [/SIZE]
[SIZE=2]textView.setText(getGroup(groupPosition).toString()); [/SIZE]
[SIZE=2]} [/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]public [/COLOR][/SIZE][/COLOR][/SIZE][/B][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]boolean[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] isChildSelectable([/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]int[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] groupPosition, [/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]int[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] childPosition) { [/SIZE]
[SIZE=2]} [/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]public [/COLOR][/SIZE][/COLOR][/SIZE][/B][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]boolean[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] hasStableIds() { [/SIZE]
[B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]return [/COLOR][/SIZE][/COLOR][/SIZE][/B][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]true[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2];[/SIZE][/LEFT]
[/LEFT]
[LEFT][SIZE=2]}[/SIZE][/LEFT]
