Popup Note App
adagosto
Hi.
Can anyone help?
You know the Popup Note app that is in the popout menu when you pull out the pen? There's that handy Popup Note app in the list.
How on earth do you get back to that app once you close it, without sticking the pen in and pulling it out again? That Popup Note app does not appear ANYWHERE that I can find. I would like access to it all the time.
If there is no way to do this, are there any apps that work like it (can be used in multiwindow, very quick one button touch and writing away....)
Any thoughts?
Thanks,
Adam
