it wont let me put two different items in the images to download section i get the first one in there and then when i put the second one in it freezes when it checks md5 file name then i tried to just do one at a time but it wont finish
BH_MAN said:To Setup the Launcher in WarHeads...
Menu > Preferences > Performance > UnCheck Lazy Mode ( Lazy Load Applications ).
Then you need to select>
Menu > Preferences > Screens > Orientation
Then, Last Step...
Load up the Terminal App.
type SU, Alway Allow... exit , exit...
That's it, all Fixed... I know it's a Pain, but once Done it's worth the effort.
thanks i have multiple loading now but my phone has been stuck on amss download for 27 minutes is that normalEnsure that the ODIN application is set to Run as Administrator and set to XP Compatibility Mode. Both of these are available by right clicking the executable and going to properties then selecting the Compatibility tab.
Is it possible to use this as my start up image?
I have done the above and rebooted the phone, but the application menu still refreshes every time I launch it, any idea?
Thanks!
People like you amaze me. It would take me a year to come up with something like that and it still would like my 7 yo drew it. lol...
You've had less than 24 hours and it looks damn good.
Anyone had any luck changing their wallpaper???
I. Before You Begin
1. THIS IS ONLY FOR DEVICES WITH 320 x 480 RESOLUTION! DO NOT USE THIS ONE ANY OTHER RESOLUTION PHONE!
2. You must have root access.
II. Setup ADB (If you haven
tried to redo this a bunch of times but i keep getting stuck at some pointthanks i have multiple loading now but my phone has been stuck on amss download for 27 minutes is that normal
Thank you so much!
here is the program to change the image to a plash screen image:
MEGAUPLOAD - The leading online storage and file delivery service
I haven't tried this yet, but those look like instructions for the G1. I mean, if the worst that can happen is that it won't work, no biggie, but I'd still let someone else try it first.
afaik, we don't have access to the spl on the BHII that way. I'd check it, but I use a G1 and I won't see the BHII until this evening.
