DISCLAIMER: By using this rom, you agree that you are the only one responsible for anything good or bad that may occur. Use at your own risk
For Boost Mobile ZTE Max N9520 only.
This is a port of the Warp 4G Lollipop ROM by @edodson84. The original Warp 4G ROM thread can be found here. I take no credit for this ROM as all the theming was done by @edodson84. All I did was port it for your device
From @edodson84 about this ROM:
This is 4.4.2 stock based rom themed with a L like feel, it is debloated and all system apps have been updated and replaced for a more L like feel, it has native root and listview animation i have included xposed along with gravity box aosp lock screen and tint status bar...
NOTE1: If you have not updated to 4.4.2 (B06), you should flash this partition updater AND the rom. You only need to flash this once.
NOTE2: Your device must have CWM/PhilZ to flash ROMs.
NOTE3: This zip is unsigned so you will need to disable signature verification in CWM/PhilZ before flashing.
Flash in CWM/PhilZ as follows:
edodson84 - for his hard work theming this ROM
- Download ROM stormer_4.4.2_Lollipop_V1.0.zip
- Put the ROM zip on your sdcard if not already
- Reboot to CWM/PhilZ Recovery
- MAKE A BACKUP!!!!!!!!!!
- Wipe data/Factoy reset
- Install partition updater from sdcard (see NOTE1 above)
- Install ROM from sdcard
- Reboot
- Enjoy!
