Thanks..I am going to factory reset for sure before selling but was not sure of the order either before or after porting..Also should I sell with or without the SIM?The device's state shouldn't affect them from being able to port the number, although I'll admit I've never had it done before.
I would definitely do a factory reset before you sell it though.
Phone is stock so a factory reset should suffice I think..thanks for advice on the sim!I would actually flash the factory image if you're running a custom rom to take it back to complete stock and then relock the bootloader. As for the sim, cut and discard it and sell the device without it.
