My Galaxy S5's battery is a 2800 mAh, 3.8 volt type, according to included specs.
Newbie questions: what kind of portable battery charger is required? I've seen battery chargers range from 1100 mAh to 12,000 mAh at various voltage outputs. Can I use a portable charger that provides WAY over 2800 mAh (such as 6000 -- 10000 mAh) and has a 5 volt output? Or do I need a charger that provides ONLY 2800mAh at only 3.85 volts? Maybe I'm over-thinking this and any smartphone charger would do. Help.
Basically, what do I need to know about portable battery chargers...? Thanks.
