Hello everyone,
I need testers for this, this is a possible workaround for the wifi issue.
DISCLAIMER: THESE FILES ARE UNTESTED AS I DO NOT HAVE THE PHONE! FLASHING THIS CAN POSSIBLY BREAK YOUR ANDROID, SO BACK EVERYTHING UP FIRST!!
I've extracted a zip file including all the 2.1 files (Kernel + Wifi libs) and made it into an Amon-RA flashable package. If you do not know how to flash update.zip files, this might not be for you. If you're curious anyways, please see the All things root forum for a guide how to flash a recovery.
The v10d-signed.zip is the old zip package which should be flashed on Gingerbread 2.3.3 to rollback the wifi portion + kernel only. If phone doesn't boot after this update, I've supplied the v20a-signed.zip to restore all files to normal.
Here they are:
2.1 WIFI + KERNEL: View attachment v10d-signed.zip
2.3.3 WIFI + KERNEL: View attachment v20a-signed.zip
Again, it is **HIGHLY RECOMMENDED** to do a nandroid backup before flashing these! If both files fail, simply restore from the nandroid you created and everything will be back to normal!
Thanks!
Here they are:
Thanks!
