IMUcarmen
Android Expert
Just wanted to let you guys know that I may have found a fix for the reboots, and whats causing them.
The cause seems to be restoring apps no matter what backup and restore app you use. I've used RTB pro and TB pro to restore apps and get reboots with both. I have had reboots with eclipse and BO.
Here's the fix. I don't know if this is 100percent but please everyone who is having issues report back after you try this.
I was on eclipse up until 2 days ago and decided to try out broken out 3 for the third time (can't help myself from flashing
) and when I did, I also decided not to wipe data just to see how well it would run, and if I would get any bugs. So I flashed BO 3 with no data wipe and all went perfect. Since then I haven't had one reboot. I've been on broken out for 2 days with 0 reboots.
You may be thinking, so what, wheres the fix. Here's my thinking...I had already restored my apps on eclipse, so I think simply reflashing the rom after you restore your apps will stop the reboots. I don't think it will matter if you are coming from eclipse or not. All I think you need to do to stop the reboots is make sure you reflash the rom without wiping data after restoring your apps.
Try this out guys and report your results.
PS. this is not applicable to those having reboots with the docking. I don't use this feature.
