I have searched the forums and found a possible solution in the mr number app but was wondering if anyone else has another app they use to block unknown numbers. Its for a friend who is getting unknown numbers calling her, I use call control and suggested the app but wasnt sure if it blocked unknown numbers and it appears it does, apologies I should have checked this before I posted.
glad you found an app that works, those are the two I would of recommended
