I don't want to root. My phone works just fine as is, except for having extra unused and unwanted apps.
Is there some way to remove them without rooting???
Haha, yeah, only 75% of it. The problem with the bloatware is that Qik, MediaHub, etc, all run in the background, and even if you kill them, then just keep coming back, even though I don't use them at all. That's a waste of resources!
Don't think so. I'm an Android noob myself, had an iphone and a blackberry before jumping ship.
There are several launchers out there where you can hide unwanted apps from showing up in app drawer. I use GO Launcher and I hide all the ATT/Samsung bloatware so I don't see them. Also, when you do a reboot of the phone, you can go to app->manage apps-running process and kill a bunch of bloatware related background services.
I'm still patiently waiting for a less confusing rooting method for ATT S2, mainly with the stock kernel and no need to flash using Odin. There's a video posted recently that shows a pretty easy way to root this phone, but the guy put together a custom kernel.
Honestly, I don't think ATT bloatware on this phone is that bad. When I bought my bb9000, it was littered with ATT crapware. Also, they are "kind" enough to let users uninstall 75% of the crapware on S2.
unrooted, there are only a few bloatware apps, like the at&t code scanner, that you can delete. i think there were about 4 total.I don't want to root. My phone works just fine as is, except for having extra unused and unwanted apps.
rooting this phone is really easy. I wouldn't be afraid of odin, if you follow the steps one by one you will have your phone rooted in about 5 minutes.
Unless you root there is no way to get rid of the bloatware AFAIK.
