Possible to view all apps ever installed?
  • Thread starter Thread starter milesbennetdyson
  • Start date Start date
M
milesbennetdyson
Guest
I've recently got a new, better phone with a lot more internal memory. I used to have to limit my installed apps that wouldn't move to SD, but now I can install what I want.
On the Play Store clicking 'My Android Apps' I can view uninstalled apps under 'Other Apps In My Library', but it only goes up to apps starting with L. I'd like to be able to see if there's some apps I've forgotten about. Is there a limit or something? Seems a bit silly.
On a desktop go to the Play Store and click my android apps and it will show all downloads for each device you have.
Yep, I tried that on the desktop version. THe listing just stops at L. Could there be a limit? I think I only have about 40 apps installed, although in the past I've tried a fair few out, like when trying to find a decent calendar widget I must've tried about 10. That's the only thing I can think of.
then when in the play store, scroll to the bottom and click My Orders & Settings, you should see everything you've ever "purchased".
Your apps under all is listed alphabetically? Mine isn't. :( What a bummer for me but I think all of the apps I've ever installed under my gmail account is in the playstore. I can keep scrolling and scrolling and they are there. If you didn't change or update your gmail account, all the apps downloaded or installed should be there.
Well this is odd, all the apps ARE on the app on my phone under 'All', but they stop at L on the website. Strange. Ah well, it's not the end of the world. Thanks for your replies guys.
The alphabetical listing is only on the website, on the app they're listed chronologically.
jefboyardee, I think we've got a winner. That worked really well, there's loads on there that don't show up on Play Store. I already had an AppBrain login that I haven't used for a while, but it shows up loads of things that the market doesn't. Thanks!
Which is strange, considering appbrain gets that list from play store. I hardly ever go to play store anymore; partly because it
Just a quick update. Since the recent update of the market app, I've been through and deleted some of the apps I know I never want to install again (under My Apps > All).
I've just logged into the market on my PC and there we have it, my list of apps has now reduced and it no longer stops at 'L'. So it seems there is a limit to the amount of apps the desktop version of the market shows.
