kjordan2016android
I've had my Android LGL33L for about 3 months now, and there has been several strange & unexplainable things happen with this phone. Here are just a few:
I got on facebook and received error message ' Can't connect right now. Check your internet settings'...But my wifi on the phone is turned off and i have 10 GB of data through Straight Talk.
I've been getting an error message while online 'Security Warning- there are problems with the security certificate for this site- not from a trusted authority'....I even got this message when I came to this website, and I know the sites are trusted.
Then when I go to the update section under Settings- About phone- Update center- Software update- Update now/Connect to server, after choosing this option, message says ' Checking the server for available software updates', then error message ' Could not connect to update-server. Please check network connection and try again'.
And under 'Update now', option ' Last Update' says ' not updated'
My current Android version is 5.0.1
Kernal 3.10.49
Build LRX21Y
Software version L33L10a
Now, as I'm sitting here writing this in Android Forum, a very light colored message pops up that says 'Draft Saved'
There are many more events like these and I've downloaded antivirus apps from Google Playstore, I've ran them all several times but they all say the phone is not infected...I'm almost sure it is and my Google accounts, emails, facebook logins, etc are on this phone as well....and if it has been compromised, it has taken over this phone. Can someone tell me their opinion, and if you think it's been compromised, what can I do/or should I do? Thank you!
Kernal 3.10.49
Build LRX21Y
