EarlyCLO
Hi all -
been basically lurking for a couple of months, since I upgraded from a flip phone and separate PDA to the Spectrum in June, trying to learn how to use it. Y'all are a wealth of information, so I hope you can help...
Since the OTA upgrade to ICS (stock phone, no rooting for me till I have a bigger clue, and no, I didn't do a factory reset before the upgrade) - I seem to be having issues with airplane mode - If I select it, there is no red airplane icon, wifi turns off, phone signal bars remain, and it's about 50/50 whether I will or will not be able to send/receive phone calls and texts - I thought it was supposed to turn off ALL radio, network, outside the phone communications... At least, that's how it worked on GB.
Anyone else with this problem? I suppose I'll end up with the factory reset thing to see if that fixes it, but I wanted to check first if it was only me...
Thanks,
Cheryl
Thanks,
Cheryl
