Post problems discussion
marc12868
Android Expert
I wanted to start a new thread discussing problems and if they have anything to do with firmware versions/ manufacture dates.
My phones info is:
Manufacture date: 7/11
HW A (whatever that means... Hardware A maybe?)
Firmware version (aka software version): 1010_2_039
The problems I have are: light leakage (doesn't bother me)
I have to use oddball kernals
Slow gps lock (cm7 and miui fix for me)
A bit of green tint when taking picture with no flash at times.
Back key doesn't like to respond all the time
Occasional screen flicker or wash out on screen wake (locking and unlocking fixes it)
Volume too loud on stock not quiet like most people complain about, but loud (cm7 and miui fixes it for me).
And I think that's about it for me.
Post your problems and the manufacture date(under battery), the HW A(or whatever it is for you... under battery in all caps by the model number), and your firmware version(have to be in stock... under click settings then its "software version".
Also check out this other thread started by iSnow if you want. Its just posting you manufacture date...
