Post-September Update Crashes
bupolo
Anyone experiencing a lot of program crashes since the September update? A lot of my widgets stop working, and I have to delete them and re-add them. And lots of other little errors where I the screen will go blank and I have to pull the battery. It's almost a daily occurrence at this point, very annoying.
Anyone else having these issues?
I have the At&t version and since I did the update the other day I have had a couple of times where the screen goes black and I have to pull the battery but they were both times when I got messages in GO SMS and the pop up came up. Not sure if it was related to the update or the app.
So not really anyone having this problems? Lots of other little things I'm having an issue with like settings turning on and off (auto rotate turning off, key press sound turning back on).
It's really weird. The phone worked perfectly before the update.
You're not alone; lots of squirrelly behavior over the past couple of weeks. Power saver turning itself on, GPS, auto rotate and data turning themselves off, notifications vibrating in my ear during phone calls. Throw in the cut and paste fiasco and it's pretty annoying.
Both me and my wife are having a lot of random issues since the update. Sometimes the screen doesn't respond to our touch, call quality has gotten bad, and alarms aren't working among other issues. Not sure what the problem is but hopefully a solution is found soon.
I've been doing just fine since the update. In fact, my wifi signal strength has improved when using my home wifi network. US Cellular R530UVXL14.
