Post Your Lockscreen Screenshots (WidgetLocker, etc.)
what clock is that?
https://play.google.com/store/apps/...GwsMSwxLDEsImNvbS5zdW5ueWt3b25nLmZyZWVvbWMiXQ..
can't decide which I like better. The solid clock or the one with the opacity turned down.
UCCW clock
Phantom music controls
Team Battery Bar
Brilliant Quotes
Invisble Iphone slider
I am sorry to go a little bit off topic....sorta. But since I've seen a lot of people using the Unread SMS app, I figured this might be a good place to look for an answer.
Does Unread SMS only track the built in messaging app? I use GOSMS Pro and I'm wondering if Unread SMS is able to track GoSMS Pro notification as well.
I have missedit but I'm looking for something similar that can generate a counter onto a custom icon widget.
I have not used GoSMS, but Unread SMS Count does work with Chomp and Handsent.
Palmary Weather
Advanced Clock
SiMi Clock Battery (tap to turn on flashlight)
Minimalistic Text (day of week, month/day)
PowerMod3 slider (right to unlock, left for camera)
Those are done using smartshift lockscreen app.
anyone has it and knows the difference between widget locker?
It seems like i can only make the unlock to scroll upwards....
Didn't realize I hadn't posted the finished version of this.
Sliders: Widget Locker default ICS and Android Default.
Temp, Battery, and Clock: Minimalistic Text
Txts and Calls: Missed It.
Pandora's Default Widget for the tunes.
I've really enjoyed the functionality and flexibility this gives me on just a single screen.
