Post Your Lockscreen Screenshots (WidgetLocker, etc.)
Cool wall can you post it?
||MaxxHD||
Ok, I have a question for you all. There is some really amazing work in here, and a lot of it requires more than just a few minutes to get it put together. So, here is the question.
Is there any way to save your lockscreen work, so that you can reuse it at a later time?
I am just getting going on working with my GS3 and am totally absorbed in it. Just seems a waste to spend all the time making new screens only to be tossed away after a few hours/day/weeks.
Thanks much.
Roger
Thanks much.
Roger
WidgetLocker has a backup/restore feature. Never used it but it has one.
This is my lockscreen. It is a theme for GOLocker. If you're interested in how I got it, feel free to PM me.
i dont have the links for the slider on the left... (its in the xda thread somewhere) The second slider is the negate ics availavble on widget locker.
Lockscreen:
Widget Locker Pro with the Rotary slider
Wallpaper from Best Wallpaper
One More Clock widget for time, date, and battery percentage
Holo Icon pack
Poweramp widget for music
Loving Widgetlocker barring one small issue.
Certain icon packs are not available for theming apps located on the lockscreen.
So here's my setup.
Top left Minimilistic text widget,
Top right Switchpro widget
Centre Missed it!
Bottom are app shortcuts but if I try use a smaller round icon such as those found in Blaque Blue icon pack or Mint Beta icon packs I'm unable to set them. When I select edit and select the icon pack I'm met with a blank screen instead of a screen populated with all the various icons!!
Any advice would be most welcome...
^ nice!
attachment.php
Sorry i don't have any links for the slider and clock.. (i will dig them up if needed)
Using WL and Axis icons pack
