Post your speed test results
Signal strength at time of testing is crucial, weak signal can limit download speeds, and even strong signal could limit downloads to 15-20mbps, while being right under the tower can result in 30-50mbps down, signal is still great, but it is a huge limiter when it comes to 4g.
In Schaumburg, IL, with only 2 bars 4G.
I get insanely fast results when I do a speed test but I've noticed that Tapatalk works at the same speed whether I use 3g or 4g (with all that speed). I have no idea why but the extra speed does not seem to translate into apps that use internet working faster. Streaming hd video is faster and better but that seems to be the only advantage.
With 5 bars in NE Iowa
G'Day Guys
Got these speeds on 4G. Best on home WiFi is 6.05/1.26/31.
Slows a bit later in the day but still solid 40+ Mbps.
Have a good one.
Test Date: Nov 24, 2012 7:41:31 am
Connection Type: Lte
Server: Perth
Download: 59.03 Mbps
Upload: 27.83 Mbps
Ping: 32 ms
External IP: 149.135.54.321
Internal IP: 100.119.12.345
Latitude: -31.94769
Longitude: 115.87845
A detailed image for this result can be found here:
http://www.speedtest.net/android/298905097.png
Ookla operates Speedtest.net using a massive global infrastructure to minimize the impact of Internet congestion and latency. With millions of tests performed every day across hundreds of servers, Speedtest.net is the ultimate resource for bandwidth testing and related information. Visit it on your computer today to find out why.
Connected by Motorola
PS. When you click on the image link above the speeds are even higher. Not sure why the difference but - hey!
