Help Postcode Option in contacts missing
scull
How do you enable an add postcode option in the address section of the contacts app ?.
I only see zipcode and that field doesn't let you add letters so is useless for postcodes .
did you use the kies hack last month to get froyo if you did thats why you cant put postcodes in your phone thinks its not in the uk mines the same
Yes I did but ive flashed jpo since then with odin and thats ment to be the official samsung uk release .
I was wondering whether its just the app or maybe i need to reformat and then flash jpo again ?
Can somone in uk check there phones contact app and see if you have a add postcode option in the address section of a contact when editing please TY.
I also get Zip and cannot enter postcode -in the UK.
All the address fields downloaded from gmail are in the first box - as they are in gmail online
Thanks for the reply it must be the app then .
It dosnt realy matter can just add a comma in country section and add postcode there.
Think I posted this in another thread, but I have no problem putting a postcode in the zip code box.
