i wanna create a connection to postgresql with jdbc.i did it with android 2.2 bu i couldt connect with android 3.2. for both application i have used the same methods but it did not connect with android 3.2.Here is the code;
public Boolean CreateConnection()
try {
Class.forName("org.postgresql.Driver");
} catch (ClassNotFoundException e) {
// TODO Auto-generated catch block
e.printStackTrace();
return false;
try {
conn = DriverManager.getConnection("jdbc
ostgresql://ip:5432/db","user", "pasword");
} catch (SQLException e) {
return false;
return true;
here is the error when i tried to run my application in android 3.2;
"org.postgresql.util.PSQLException: Something unusual has occured to cause the driver to fail. Please report this exception. "
in addition i get the permission in the manifest.xml and i used that jar file
ostgresql-8.3-606.jdbc4.jar
thanks for helping me.
try {
return false;
try {
ostgresql://ip:5432/db","user", "pasword");} catch (SQLException e) {
return false;
return true;
ostgresql-8.3-606.jdbc4.jarthanks for helping me.
