Power Bar Widget
awriternot
I think I'm using the stock power bar widget (Bluetooth, Wi-Fi, screen adjust, GPS) & it has a black background.
Does anyone know of one that you can adjust the opacity of the background to make it see through (clear)?
I don't believe you can with the stock power bar. I use the app Widgetsoid and you can create switcher bars with functions of your choosing and it also allows you to adjust background opacity. Might give that a try.
SwitchPro is another good one too. Very customizable. Been using it for years and you can add the toggles to your drop down rather than add a widget to your screen, if you prefer.
Just as info, Widgetsoid has this same capability to add toggles to your pull down notification bar as well.
