Help Power botton
It's nowhere near 2 seconds but mine does seem to have a slight delay when pressing the power button. If I turn it on with the home button that delay isn't there. Have you tried that?
Not on mine. Sometimes something like that can just be an easy fix. Do you restart the phone everyday? Or maybe just try taking the battery out for a sec and then turning it back on. Surprisingly this helps. Sometimes I notice a little lag but never 2 seconds. If I restart or take out the battery then it's all back to normal for me. You could try that
