Power button broke..
DoAndroidDream?
It seems to be loose and all the way down. This just happened today. Possible work around?
Is it possible to map the power button to a keyboard button? The D-pad for example?
Same thing happened to my phone. If you don't have insurance, like I didn't, call motorola and check the warranty on it. If its under warranty they will fix it for free, if its out of warranty you can still have it fixed by them for $$ (which is still cheaper than buying another phone). This happened to both mine and my wifes phone within a month of each other and both were under warranty and fixed for free.
-Ryan
No way to map the power button that I have ever heard of. As the previous poster said see if you have a warranty that is still in effect and then take it back to Verizon.
This happened on my previous Droid and also on the one I currently have now. As far as I know, there's no way around it, just have to press it on the right spot.
