Power Button hardware failer (SOLUTION!!)
jSavvy1641
Member
Hey guys a while back I made a thread that had to do with my sisters Samsung G.P she had an issue where here power button worn out is wasn't able to work. Well long story short same thing happend to me recently, and I don't know if anyone else is having this issue but luckily I found a way to fix it.
This is simple just go into play store and download and app called "Power on Volume" This app basically switches the original power button with your prevail or androids volume button in order for it to unlock. This is a good temporary fix until you can get it repaired or a new phone most likely you won't need repairment.
Link to app (Google Play) - https://play.google.com/store/apps/...e&utm_medium=organic&utm_term=power+on+volume
